A list of official 2023 Mercedes-Benz EQB key technical specifications can be found here.
EQB 300 4MATIC
EQB 350 4MATIC
EQB 300 4MATIC | EQB 350 4MATIC | ||
Drive system layout | All-wheel drive | ||
E-machines front/rear axle | Type | Asynchronous motor (ASM)/ Permanently excited synchronous motor (PSM) | |
Output (peak) | hp | 225 | 288 |
Torque (peak) | Lb-ft | 288 | 384 |
Top speed1 | km/h | TBA | |
Battery capacity, usable (NEDC) | kWh | 66.5 | |
Combined consumption (NEDC) | kWh/100 km | 16.2 | 16.2 |
Range (WLTP) | km | 419 | 419 |
AC charging time2 | h | 5:45 | 5:45 |
DC charging time3 at quick-charging station | min | 32 | 32 |
EQB 300 4MATIC
Drive system and battery | ||
Electric motor(s): | Type | Front axle: Asynchronous motor (ASM), Rear axle: Permanently excited synchronous motors (PSM) |
Battery type/usable energy content (WLTP) | kWh | Lithium-ion/66.5 |
Rated voltage | V | 367 |
Recuperation capacity, max. | kW | 190 |
AC charging capacity, max. (onboard charger, standard/optional) | kW | 11 |
AC charging time2, three-phase (11 kW) | h | 5:45 |
DC charging capacity, max. | kW | 100 |
DC charging4: range after 15 minutes (WLTP) | km | approx. 140 |
Suspension | ||
Front axle | MacPherson suspension with spring strut and transverse control arm, coil springs, twin-tube gas-filled shock absorbers, stabilizer bar | |
Rear axle | Multi-link, coil springs, gas-pressure shock absorbers, stabilizer | |
Brake system | Internally ventilated disc brakes at the front, electric parking brake, ABS, Brake Assist, ESP® | |
Steering | Electrically assisted rack-and-pinion power steering system | |
Dimensions and weights | ||
Number of doors/seats | 5/7 | |
Length/width/height5 | in | 184.4/72.2/65.6 |
Wheelbase | in | 111.3 |
Turning circle | ft | 38.4 |
Cd value from/Frontal area | -/m2 | 0.28/2.53 |
Performance, consumption and range | ||
Acceleration 0-100 km/h | s | 8.0 |
Maximum speed | km/h | 160 |
Max. range (WLTP) | km | 419 |
EQB 350 4MATIC
Electric motor(s): | Type | Front axle: Asynchronous motor (ASM), Rear axle: Permanently excited synchronous motors (PSM), |
Output (peak) | hp | 288 |
Torque (peak) | Lb-ft | 384 |
DC charging time3 at fast charging station (DC) | min | 32 |
Suspension | ||
Brake system | Vented disc brakes at the front, electric parking brake, ABS, Brake Assist, ESP® | |
