It might be a profile thing, I have mine set to DAuto and it always starts up in that setting, try saving your profile with it set and see if that saves it.It seems to me that the D setting makes the car behave much like an ICE car as regards braking so having that as the default setting is a good idea for drivers new to electrics so they have time to get used to the differences. Having D+ as a default for example, could result in a novice electric car driver having an accident due to the car freewheeling when they were expecting engine braking and a default D- setting could give a fierce deceleration on lifting off the accelerator too quickly when a more gradual slowdown has been expected, a default D auto setting could also be a problem as I find the amount of braking you get is a bit unpredictable and I usually select D or D- in town traffic for that reason. It’s not as if it requires a lot of effort to change the setting by the paddle, just an action you soon get used to.
Maybe it's only D Auto that gets remembered, I may do some experimenting when I have time. I know that if I change when driving, for instance switching to D-- in hilly terrain and go back to D Auto, it always starts up in D Auto. I'll see what happens if I leave it in another setting when switching off.Thanks for clarifying that, EddieHeli. I am currently driving in Eco (low speed suburban driving) and set the regen to D-. When I begin a journey, the prompt to continue in Eco shows on the top left of the left hand screen, which I tap to accept, but I still have to remember to set D- manually. In other words, it doesn't seem to remember that I was driving in EcoD-.
Yep, that seems to explain it then. I have found D Auto to be great for everyday driving and only change to max regen when going down steep hills.My Owner's Manual (page 145) says the following:
"When the vehicle is started again, the following recuperation level is set:
D Auto: if D Auto was selected previously.
D: if a recuperation level other than D Auto was selected previously."
It then explains the processes to set other levels of recuperation. Your experience, EddieHeli, seems to be consistent with the D Auto aspect of this.
D+ mode is good for the breaksI prefer the stronger braking effect of D-, but I'll continue to experiment and possibly in other driving conditions other settings will better suit my driving style.
Thanks for your post. She did try D Auto but she seems to prefer the D+ setting and will just learn to live with changing it as she drives. I think she figured out the radio setting also but I am not sure what she did on that item yet. She is loving her vehicle and we are adjusting to the EV life.Has your wife tried D Auto? As the thread above says, other EQ Mercedes are able to default to that setting.
Personally, one aspect of my EQA250 which appeals to me is the ability to alter the regenerative braking level according to the conditions at the time. I use the paddles to, for instance, change from D+ or D to D- or D-- as I approach a roundabout or stop sign (in urban driving). Depending on the circumstances - and other traffic - as I round a roundabout, I often change from D- to D or D+ as I exit. I enjoy this interactive driving experience - and economical use of the brakes - but, I appreciate, it's not for everyone.
I'm not sure about the radio question. I've never used Favourites; perhaps 'low volume on start up' can be configured in there somehow. Otherwise, to mute the radio, I'd just press either rotary volume wheel after pressing the start button. Or do the same just prior to turning the car off?
I agree. I like to use D+ the most. It seems to suit my driving style and my environs the best.D+ mode is good for the breaks
How do you save your profile?I don't think you can set it the settings, but what I meant was that if you have it set to your preferred option then save your profile, it seems to start up in that setting. That's what mine did with D-Auto, so it may save it in the background.
