As I anticipated with the minus deg temps here the low coolant warning message comes up when I first use the car, I have done nothing but short or shortish journeys, and usually after the initial message it does not return until after a long park up. I responded to another thread about an EQV loosing coolant today and I add this info to this thread:-
“The first time I checked the levels in the tank on the left which is the one you check the level in according to my EQC manual it just covered the T marker at the bottom ie at the level it should be apparently. This am before using the car I went out and checked it and the level was to the top of the tank and the one on the right also had liquid as it always has had about half full. I got the message only on the drivers screen not on the central screen ( I have seen a message there before in basic script like DOS in windows which inc the message go to the garage) but it did not register in the maintenance messages. The liquid was warm not hot but warmer than ambient (it was around -2.5C). Went out did some short journeys and the left tank stayed at the same level. The car has been on charge today and the level was the same after a few hours the left tank was no longer above but was at ambient temperature the right was warm so liquid is clearly circulating around as the battery was charging (from 18 to 60% so the lower end of the range), and indeed I have often heard it trickling back into the right side tank at all sorts of times and scenarios.
I am now left wondering where is the sensor that says the liquid is low as the tank I am required to fill looked full? Perplexing but it does not sound quite the same as your issues.
I really do not want to go back to my garage if I can resolve the issue by just putting some liquid in as it is a 200km 2.5hr round trip so a pain in the proverbial as it is to get MB antifreeze is an hours round trip. I will drop them a line and see what they say but I expect the usual bring it in for us to look at it response which is not that simple!”
I will keep this thread updated.
