Leave the rotary switch in Auto, but move the stalk to the low beam setting (towards the driver).
Yes, the EQA does seem to differ from the EQC: the indicator / headlamp beam stalk only has a momentary (spring-loaded) switching function, either towards the driver or towards the dash, from a resting central position.I just had a read of the EQA owners manual, and it looks like it is indeed different. Does your stalk only have one position it can rest in, with both towards the dash and towards the driver being spring-loaded?
Referring to my previous posts, I drove the car again last night and without any 'in-out' (towards dash-towards driver) movement of the indicator stalk, the previously-disabled automatic high/low beam function seemed to retain its functionality after several restarts (i.e. the headlamps turned on automatically and remained on low beam, even in dark areas where one would expect them - without auto low/high beam disabled - to switch to high beam).I reiterate that I hope my present setting for the Auto headlamp function is maintained between journeys; otherwise, it's just another thing to have to keep resetting. From memory, I think the car will retain my present setting as long as I only move the indicator stalk to activate the indicators.
Yes, my EQA250 is the same; however, I am unsure whether the EQS has the same momentary switch (steering column lighting stalk) function as my EQA, or whether it's similar to dBC's EQC (see posts #5 and 6 above).I have an EQS and when the lights are set to auto with high beam option they automatically dim when an oncoming car is detected. Not sure if your model does the same.
Yes, the Devil's Elbow is still there, and the winding section of road running up past the old Eagle-on-the-Hill hotel can still be used (at low speed, apart from closed-road motor sporting events), but since the late 1990s the section of road from just below the Devil's Elbow to Measday's Hill (just below Crafers) has been replaced by a 6-lane freeway. The freeway is much straighter than the bypassed section of road and much steeper - and includes a short tunnel. The new road is much quicker - but less interesting - for light vehicles, but the steep gradient has caught out several heavy vehicles and there have been some nasty accidents at the edge of the city due to brake failure (i.e. the drivers of those heavy vehicles haven't selected a sufficiently low gear for the descent).Ahh Good Old South Australia where all good things are born including me... the place I learnt to drive for 26 years.. Is the Devils Elbow still there when you are coming into Adelaide ???
I wouldn't say headlamp flashing is common here, but you do see it from time to time. Sometimes, during daylight, drivers flash to warn oncoming motorists that they're approaching a speed camera. Given that the stated aim of speed cameras is to encourage drivers to keep their speed in check, perhaps in this context the headlamp flash can be classed as a community service, although I don't think the police would agree.The old high beam flash not as common here in Netherlands where I live now but I do recall when driving back down under when I had an X3 which was around the same size as the EQA I got flashed all the time because the lights sat higher they were hitting people right in the eye-line.
If you leave the lighting switched to Auto and you haven't noticed your EQA300 switch to high beam when driven at night in poorly lit areas - or areas without other traffic - maybe it's currently configured so that it's not switching to high beam in such circumstances. That's how my EQA250 is currently configured. I presume, of course, that the the Netherlands motor vehicle regulations permit automatic low/high headlamp beam activation.I haven't noticed my High Beam coming on here in Amsterdam when driving around the city but I have only had the car a few weeks and haven't really done a lot of night driving and wont now as we are rolling closer to summer the daylight is crazy long here so I wont get a real chance to see how much I will miss my old A200 Sedan's MultiBeam LED's until winter when its dark around 16:30 and you dont see the sun again until 09:00
I agree, there's some smart technology about and no doubt it will only improve with time.I dont understand why Mercedes didn't put the Multibeam Option on the EQA as its available on the GLA I think its a real oppurtunity missed. It was very intelligent lighting and I think you would find in S.A a big reduction on being flashed as the MultiBeam LED cuts the light out around the oncoming car , pedestrian even street signs that have higher reflection. You really do get to see it at work during fogy days and looks impressive. Alas I will have to make do with what the EQA has but I do understand your point about being a responsible road user I wish more people acted that way today but sadly we are a rare breed
