Took delivery of a new UK 2022 spec EQC AMG Premium yesterday and bit confused with what elements of Mercedes Me connect services are complimentary.
I currently have acces to the following via the app:
Anyone able to advise the entire complimentary services I should have access to, or is that it and I need to purchase the ‘Excellence Package’ to access these?
Some services are showing as ‘activating’ in the web portal, so not sure if I’m just being impatient or if there’s something else afoot. Seems a bit odd their being such a lag between some services being activated.
I also had difficultly registering for the app, services and MM Charge via iOS and OS devices and had to use a windows machine in the end.
Very pleased with the car so far too I should add.
Should also add in the app the MM Connect Services is showing as ‘incomplete configuration’ but when I select ‘overview of services’ the just loads a blank screen with a permanently spinning disk.
- Charge Status
- Pre Entry climate (but not setting the actual temp)
- Geofencing
- Over Air updates
