Might not be identical circumstances at the time of charge though. Ie if those vehicles where connected when there’s no other load on the main supply it will max out. If you are connecting / checking when theres enough appliances / load drawing equipment running it would limit load to the wall box.I do. But the same applies when connecting other cars. Why is limiting just for the EQC? The GLC Hybrid gets 7.4kW 100% of the time I connect.
bit of a long shot I guess as you would have been very unlucky if every time you’ve connected there’s been sufficient 3rd party equipment draw to limit the wall box…
Only way to rule it out would be to connect a vehicle that’s getting full power and swap it for yours immediately so see what your gets (assuming you haven’t done that already 🤷♂️)
