Having the EQC since Oct 2020, these things annoy me!
Other than that the car is great.
Anyone else relate?
Johnny
- wind noise coming through front driver and passenger windows when traveling anything over 50mph
- the ear drum popping oscillating effect if you drive anything over 30mph with one of the rear windows fully down
- the inconstant brake peddle feel. I am convinced MB have an issue with this and will start a recall. (see other thread) I have zero confidence in bringing the car to a halt in a safe and controlled manner sometimes.
- regen disconnecting every time you are using it to slow the car and the car goes over a pot hole
- power being cut every time you are accelerating and go over a pot hole
- the doors open interior light enable/disable button on the roof console that if you turn it off has an annoying red light which completely distracts in the corner of your eye especially at night
- the positioning of the charging socket on the drivers side that means for me I have to run my home charging cable from the passenger side, across under the rear of the car which ALWAYS triggers the sensor and causes the boot to open!
- the boot not opening when i try to use the sensor with my foot!!!
- the in-lane assist which you cant permanently disable. It can catch you off guard sometimes and when it pulls you back into lane it also brakes too which can be scary when not expecting it.
- the auto braking that can beep for no particular reason distracting you to look at the dashboard to see what the hell is going on
- the fact that it doesnt like going round corners
- the mercedes me app not having a charge scheduling option so when my home charging unit is set to provide power between 00:30-04:30, if i plug in any time before or after these times my iPhone pings me a mercedes me charing error notification every 12 mins annoying minutes. (sent mercedes me app developers a request to add this simple functionality several times to no avail).
- the battery charging progress not being constantly present on the display when charging and sitting in the car.
- range...i think we can all relate to this. its just not good enough for a mb branded car unfortunately, but good attempt!
- being beaten off the lights by a model 3!
Anyone else relate?
Johnny
