Hi, i have noticed that you need to ensure the heater is switched off to avoid losing approx. 40+ miles. Often you won’t notice it’s on (there is no light!) so you actively have to switch off. I had to use the heating to clear the windscreen momentarily. I noticed that the range reduced by 50miles. After 20seconds I switched it off expecting the range to recover. After 10mins I clicked the switch down to switch off again and the range topped up. I didn’t get the full 50miles back but it was something. I was not aware of this. And given it’s possible that you will need to clear the windscreen multiple times on a trip it is not viable to lose 50miles each time. Does anyone know why it was designed this way? Clearly it won’t take 50miles of battery to clear a windscreen. Keen to hear if anyone else has any tips like this. Thanks
