According to the EQS SUV owner's manual (pages 416 - 418) there are three fuse panels in the car. One in the passenger footwell, one on the driver side dashboard, and one below the under cargo storage compartment. Of these three, only the one in the passenger footwell is easy to access.
According to the Fuse Information Sheet (part number 297-584-84-02) stored on the side of the fuse panel under the rear cargo floor, there are as many as seven (7) fuse panels in an EQS/EQE. The fuse information sheet seems to be for all of the EQS/EQE variants.
I was determined to locate the fuse panel under the floor of the cargo area. Unfortunately, there is no access door to expose the fuse panel. I had to remove the plastic panel at the rear edge of the cargo area first. This panel is held in place with one screw (#30 torx drive) in the center of the panel and six clips along the top edge of the panel. After removing the screw I used a couple of trim removal tools to disengage the clips along the top edge.
Once this back trim panel is removed the rear most flexible liner on the bottom of the storage compartment can be easily removed. It is held in place with four pins that are easily identified.
All of the fuses in the panel are "E" style fuses. They are difficult to remove and a tool to remove the fuses is not provided. Each fuse is "locked" in place with a small tab that must be pushed aside before the fuse can be removed.
To facilitate future replacement of fuses I cut an opening to make a flap in the storage compartment liner. I cut three sides of the opening and left the forward most edge mostly in place to act as a hinge. I say mostly in place since I only left two 2" long uncut sections to act as a hinge. I believe the dealer would do the same thing the first time they replaced a fuse since there is a piece of insulation glued to the bottom of the liner spanning the area I left as a hinge. I added a small plastic T-nut to keep the flap in the closed position. If you undercut the three edges of the flap it will keep it from falling through the liner.
The most likely fuse needing to be replaced in this panel is the one for the 12v accessory socket. In my case this is the 25A fuse in the F401 location. Given the effort to remove the trim panel and storage compartment liner, I suspect that the dealers cut a flap in the liner similar to what I did. Otherwise they would have to charge $150 just to change a fuse.
Rear cargo trim panel with trim removal tools. Note one screw in center.
Inside view of rear trim panel showing six plastic retaining clips.
Storage compartment liner with four retaining pins. One in each corner.
Fuse panel below sub-floor storage compartment.
Close-up showing retaining tab on one end of fuse.
Flap cut into flexible liner with Xacto knife. T-Nut keeps flap closed.
Closed flap with T-nut twisted into locked position.
Access to fuse panel through flap in storage compartment liner.
