Hi,
I recently purchased an EQC and was told that once I have a wall box fitted I can charge the battery from 0-100 in approx. 10hrs. I have since had a BP Chargemaster inform me that due to my home cabling the max I could achieve is between 3-3.2kw. This is no different to a 3 pin charger which takes approx. 40hrs to charge. Unless I’m missing something, there is no benefit in me having a wall box installed. I know the infrastructure for charging is not there but I did not appreciate that I would have problems with my own home framework. At least Mercedes did not mention this to me nor does the brochures mention that the estimated charge times are based on XYZ. Would be grateful to get your thoughts on this.
thanks
thanks
