First long haul on EQB.
Quite apprehensive re charging. Saw a lot of ferentic ringing and running around to get the mercedes me charge card working. I am yet to receive mine. App is not set up for charging. Called Mercedes SOS and they suggested using the navigation on MBUX to find the charger. Ioinity in Cullompton but system recognised only charger 4 and 5 one occupied and other faulty.
Finally worked out that selecting either one of the detected chargers then brings up a further list and you can then select charger you want from that list. 25 p per kwh if you use MBUX as opposed to 69 p regular cost.
Just thought to share this as it is not common knowledge.
