Specifications for the Mercedes-Benz EQE SUV:
Specifications for the Mercedes-AMG EQE SUV:
*U.S.-specific figures to be announced closer to launch
EQE SUV | ||
Drive system and battery | Rear wheel or all-wheel drive | |
Electric motor(s): | Typ | Permanently excited synchronous motor(s) (PSM) |
Output | kW | -1 |
Torque | Nm | -1 |
Rated voltage | Volt | 330 |
On-board charger (standard/optional) | kW | 9.6 |
Battery capacity, usable | kWh | -1 |
AC charging time, three-phase (11/22 kW) | h | -1 |
DC charging capacity, max. | kW | 170 |
DC charging time at fast charging station3 | min | -1 |
DC charging: max. range after 15 minutes4 (WLTP) | km | -1 |
Vehicle | ||
Length/width/height | in | 191.5/76.4/66.4 |
Wheelbase | in | 119.3 |
Turning circle (without/with rear axle steering, 10°) | m | 40.4/34.4 |
Trunk volume VDA4 | Cu-ft | 18.4/20.5-59.2 |
Range | ||
Range (WLTP) | km | Depending on the vehicle equipment and configuration, the European versions are expected to have WLTP ranges of more than 550 kilometers5(with the exception of AMG models). |
Drive system and battery | ||
Electric motors | Type | Two permanently excited synchronous motors |
Rated output | hp | 617 / 677 with AMG DYNAMIC PLUS Package |
Rated torque | lb-ft | 701 / 738 with AMG DYNAMIC PLUS Package |
Drive system | | AMG Performance 4MATIC+ fully variable all-wheel drive |
Battery type | | Lithium-ion |
Rated voltage | V | 328 |
Battery energy content, usable | kWh | 90.6 |
Recuperation capacity, max. | kW | 260 |
AC charging capacity (series/optional), max. | kW | 9.6* |
Suspension | ||
Front axle | AMG RIDE CONTROL+ with four-link front suspension, air suspension strut, Adaptive Damping System and AMG ACTIVE RIDE CONTROL active roll stabilization | |
Rear axle | AMG RIDE CONTROL+ five-link independent rear suspension, air suspension strut, Adaptive Damping System and AMG ACTIVE RIDE CONTROL active roll stabilization | |
Brake system | Dual-circuit hydraulic brake system; front: 16.3x1.3 in (415x33 mm) brake discs, internally ventilated and perforated, 6-piston aluminum fixed caliper; rear: 14.9x0.9 in (378x22 mm) brake discs, internally ventilated and perforated, 1-piston aluminum sliding caliper; electric parking brake, ABS, Brake Assist, 3-stage ESP® | |
Steering | Electromechanical speed-sensitive power steering with rack and pinion, variable steering ratio (12.8:1 at dead center) and variable power assistance, standard rear-axle steering (9.0°) | |
Wheels | Front: 9.5 J x 21 ET42 / Rear: 9.5 J x 21 ET 42 | |
Tires | Front: Michelin Pilot Sport EV MO1 275/40 R21 Rear: Michelin Pilot Sport EV MO1 275/40 R21 | |
Dimensions and weights | ||
Number of doors/seats | | 4/5 |
Length / width4 / height | in | 192.1 / 76 / 65.8 |
Track, front / rear | in | 65.1 / 65.3 |
Turning radius | ft | 35.8 |
Cargo capacity, VDA | cu-ft | 18.4-59.2* |
Curb weight / gross vehicle weight / max. payload | lb | 5,930 / 7,044 / 1,113* |
Towing capacity (braked / unbraked) | lb | 3,968 / 1,653* |
Performance, consumption and range | ||
Acceleration 0-60 mph | s | 3.4 est. (with AMG DYNAMIC PLUS package) |
Top speed5 | mph | 137 / 149 (with AMG DYNAMIC PLUS Package) |
Range (WLTP)6 | km | 375–470 (provisional)* |
