1 - 1 of 1 Posts
Here is the full list of technical specs for the EQS.
Key technical data
EQS 450+EQS 580 4MATIC
Drive system layout Rear-wheelAll-wheel
Electric motor(s)ModelPermanently excited synchronous motor(s) (PSM)Permanently excited synchronous motor(s) (PSM)
Max. powertrain outputkW245385
Max. torque transmission outputNm568855
Acceleration 0-100 km/hs6.24.3
Top speedkm/h210210
Battery energy content, usable (WLTP)kWh107.8107.8
Rated voltageVolts396396
Energy recovery capacity, max.kW186290
On-board charger (standard/option)kW11/2211/22
Charging time at wallbox or at public charging station (AC charging, 11/22 kW)h10/510/5
Charging time at a rapid charging station (DC)min3131
DC charging capacity, max.kW200200
DC charging in 15 minutes (WLTP)kmUp to 300Up to 280
Combined fuel consumption (WLTP)kWh/100 km20.4-15.721.8-17.4
CO2 emissions (WLTP)g/km00
Combined fuel consumption (NEDC)kWh/100 km19.1-16.020.0-16.9
CO2 emissions (NEDC)g/km00
Vehicle
Length/width/heightmm5216/1926/15125216/1926/1512
Length/width/height (USA)mm5265/1926/15135265/1926/1513
Track front/rearmm1667/16821667/1682
Turning circle (with rear-axle steering 4.5°/10°)m11.9/10.911.9/10.9
Boot capacity, VDAL610-1770610-1770
Weight in roadworthy conditionkg24802585
Payloadkg465-545475-550
Perm. gross vehicle weightkg2945-30253060-3135
cd value from 0.200.209
1 - 1 of 1 Posts
