Same here😡
Try selecting a destination that is out of range. The car should suggest one or more charging stops depending upon the distance.View attachment 1993
Up until recently I saw the charging stations and their availability on the map. Now they are gone without changing anything. Anybody any idea?
Have you set use navigation intelligence for the route planning?Hello Guys,
I have the same problem with my EQS 450 + that is not calculating the charging time and it won't says where I should stop for charging. It just says you won't have enough power to reach the destination.
Do you have any update solution for that ?
Don't think I have Parkwood .... is this on the car or app? Not seen that.Have you set use navigation intelligence for the route planning?
Yes it can be set when checking routing in the app when you open the navigation you get a map hit the cog top RH of the screen it opens another page choose navigation with electric intelligence and a new page will open where you can choose to navigate with the charge the car has at that point or set your own, useful is preparing for a trip where you know you will leave at x amount ie 100% for example, and then the levels you want to have when at the charging stations and destination and the navigation system plans accordingly. You can also screen for Mercedes me charge stations only. When you look at the route you can toggle the Navigation with electric intelligence. You can also switch it on in the car navigation system it will be in the manual or on line guide😉but here is the EQC explanation from the on line guide.Don't think I have Parkwood .... is this on the car or app? Not seen that.
