There is one workaround for the accelerator pedal - kind of: since "0 acceleration" position depends on the regeneration setting, if you put the car in coasting mode it will feel lighter since ANY pressure on it will produce power, while for the other modes with more regeneration the initial part of the pedal range is reserved for regenerative braking action, so you have to press more and harder for the same amount of power.
