I assume you meant 1.5 years and not 15 years
Not sure why you would think changing the wipers would help unless the noise is while using them.
By design the wipers are tucked away below the aerodynamic flow of wind when not in use so unless you are using them and the noise happens I doubt that would be a reason for noise.
I haven't had any noise issues on any MB I have ever owned however I did have issues twice with a BMW X3 turned out the the door seal had broken away and at speed caused a wind noise. Also had a similar issue with the Sunroof seal but the noise wasn't as bad as the door seal
But it could be anything there are many threads on here talking about the vent at the from that opens and closed so maybe that is stuck open or closed or has something stuck in it.
Also have you looked under the car make sure nothing is out of place or hanging that it would catch wind and when at speed would make a loud noise.
It will be interesting to hear what your dealer says the source of the noise is
